B S 16hp twin spark problem
Kevin O'Hare
07-25-2005 07:52:07
Mongomery Wards lawn tractor with a B & S 16hp twin seems to have an intermittent spark problem. I took it apart down to taking the flywheel off and when I put it back together it started. The reason I took it apart was it wasn't starting. I disconnected the ground wire and checked for spark. Was visible but seemed weak. Reconnected the ground wire still had spark and still seemed weak. Put it all together and she started up. Used it for 2 hours Saturday, shut it off, went out a couple hours later and it won't start again. Checked for spark with and without the ground wire and I can't see any. Could I have an intermittent coil problem?
don watts
07-26-2005 05:18:05
 Re: B S 16hp twin spark problem in reply to Kevin O'Hare, 07-25-2005 07:52:07
yes thats the first sign of a coil goin bad .runs for about 2 hrs then wont start till it cools off .replace the coil and i think from what your describing and it oughta fix you up .good luck don
Kevin O'Hare
07-26-2005 06:36:08
 Re: B S 16hp twin spark problem in reply to don watts, 07-26-2005 05:18:05
Thanks. I'll get a new one.
