Cub cadet quits after warm up
charlie
06-13-1999 08:13:29
cub 1650 runs fine for 10 minutes or so then dies. If I pull the choke on it will catch and run but not well. Its almost like its getting no gas. New spark plug and air filter. What next?? Carb cleaner?? thanks.. charlie
chris
06-13-1999 14:17:43
 Re: cub cadet quits after warm up in reply to charlie, 06-13-1999 08:13:29
HI , CHARLIE CHECK YOUR FLOUT BOWL VENT TO SEE IF IT NOT PLUGED. ALSO CHECK FUEL FILTER IN TANK FOR
PARTIAL BLOCKAGE.
YOUR PROBLEM SURE DOES SOUND LIKE ITS FUEL
RELATED.
GOOD LUCK!
charlie
06-15-1999 21:49:17
 Re: Re: cub cadet quits after warm up in reply to chris, 06-13-1999 14:17:43
thanks Chris. Took the carb off and found a blockage right at the bowl inlet. Works like a champ now... thanks again...charlie
