127 Cub Cadet slow to warm up
T. Friesen
08-10-2005 13:31:59
I have a 127 Cub Cadet that starts easily but has no power. The longer it runs, the more power it has. After about 30 minutes it runs like a champ. Recently checked the valve settings, new plug, new battery, cleaned carburetor. Any ideas as to what's going on?
Thanks in advance.
stronics
08-10-2005 14:14:16
 Re: 127 Cub Cadet slow to warm up in reply to T. Friesen, 08-10-2005 13:31:59
Sounds like it could be running lean, maybe a dirty main jet or not properly adjusted.
Air leak? Does it run better with a little choke while its warming?
David
kdagenais
08-10-2005 14:45:32
 Re: 127 Cub Cadet slow to warm up in reply to stronics, 08-10-2005 14:14:16
Sounds to me more like a valve job needs to be done. The kohler engines are famous for losing power when the valves are dirty. A simple compression test should tell you for sure. IF the compression leaks down after cranking then most likely it is the valves or bad head gasket. Take a look and let us know your progress.
