444 no start
gary case
08-21-2005 15:08:56
just come back with my new 444 '76. starter cable was loose and i tightened it up ,but the terminal started to move. well i moved it a few more times trying to tighten the nut.tried to start but not getting anything. when i hook up jumpers to the kinda dead battery, it acts like i hooked 'em up backwards. my charger doesn't work now to.i'mnot getting any juice down to the starter-gen.also where is the drain on the hyd res.? help! thanx gary
Bill Herter
08-24-2005 18:34:47
 Re: 444 no start in reply to gary case, 08-21-2005 15:08:56
First: there is no drain on the hydrolic reservoir tank. It is under the tractor on the travel control valve. You have to remove the quarter inch hex socket plug. When you remove the plug, hydrolic system will drain but not completely (so have a pan ready). You need to remove the spark plug wire and ground it. (yes this has to do with the hyd sys) As system drains crank the engine. BE SURE THE SPARK PLUG WIRE IS OFF THE PLUG!!! You don't want the tractor to start. Replacement oil (NOT hydrolic fluid) should be either 20/40 or 15/40 weight. DO NOT FILL THE RESERVOIR ANY HIGHER THAN 3-4" FROM THE TOP. (stick your index finger in the hole at the top of the tank and if you can JUST touch the oil, that is enough) Do not allow any dirt to enter the reservoir or drain plug area. After filling reservoir w/about 3 qrts, start tractor and try to move it forward or backward 2-3 feet 2 or 3 times. If tractor jerks, or squeals, turn it off and add another quart. This allows oil to circulate thru system and release any air.
SECOND: From what I can understand about the starting situation, when you went to tighten the nut, did you use 2 open end wrenches on the terminal? You need to hold the bottom nut stationery and tighten the top nut. But seeing that you have tried to tighten your cable to the starter, you may have twisted and broken the sodder connection inside the starter/generator.
gary case
08-28-2005 15:31:45
 Re: 444 no start in reply to Bill Herter, 08-24-2005 18:34:47
thanx alot bill for the info. the next morning i went out and thought for a minuate. the solinoid wasn,t clicking. had one and tried it,fired right up let it run shut itdown then tried to start it and failed. so i think it's the switch. sometimes it cranks sometimes not. could that be the solder broke up inside the starter-gen? guess i should check it out gary
Bill Herter
08-28-2005 18:01:20
 Re: 444 no start in reply to gary case, 08-28-2005 15:31:45
Okay, try checking your connections on your ignition switch for corrosion and rust. Use emery cloth or sandpaper. If still a problem, you may need a new ignition switch. New switch is about $30. Do not buy an off market ignition. Go to a Case/Ingersoll dealer. The only other way I can help, is I will need the year of the tractor, need the PIN # off the tractor below the steering wheel (where you sit) on a silver tab.
