400 Deere acting up
dwsia
08-23-2005 13:54:23
my 400 l&g starts great, mows for 20 min. then shuts down, then will not start. waited 1 hour and the thing started right up. mowed 20 min did the same. i put in a new condensor, took off motor sheilds and cleaned around heads and cylinders with compressed air, checked air filter,ok. still does it, any suggestions?
JT
08-23-2005 17:57:30
 Re: 400 Deere acting up in reply to dwsia, 08-23-2005 13:54:23
Process of elimination, my friend. First thing to do, get a can of carb cleaner, carry it with you, when it dies, take off off air filter, shoot a little in the intake, try to start, if it starts, you have a fuel delivery problem. If it fails to start, you could have a coil going bad. Normally this is the way a coil acts. Did you also replace points when you replaced condensor? could have points acting up also. check it out first, coils are in the neighborhood of $100.00
tractornutjd
08-23-2005 17:56:56
Hi dwsia. This could be a fuel problem or spark problem. Run it untill it quits and check for spark. If no spark is found than your coil is getting affected by heat/ breaking down, and will need to be replaced. If spark is found, than the fuel pump might be acting up or the tractor is vapor locking. Look at the vent in the fuel cap and check the fuel line. Make sure that it isn't resticted. Good Luck, tractornutjd.
stromsd
08-29-2005 10:16:32
 Re: 400 Deere acting up in reply to tractornutjd, 08-23-2005 17:56:56
I have a JD316 that did the same. Mine ended up being the electronic egnition module.
