Cub Cadet 1872 Super Garden Tractor Won't Start
Al Duresa
08-24-2005 07:03:40
My tractor quit on me the other day and upon inspection I found that the connection to neg. side of the amp meter had vibrated to the point the connector just sheared off. I reconnected with an aligator clip and was able to crank the engine. I figured I found the source of my problem. When I went to make the connection permanent I accidently shorted the positiov side of the amp terminal and now the engine won't crank again. I looked for a fuse but was unable to find one. Any suggestions where the fuse might be or what I might of shorted out?
R Bedell
08-24-2005 07:43:14
 Re: Cub Cadet 1872 Super Garden Tractor Won't Star in reply to Al Duresa , 08-24-2005 07:03:40
Might try a looking at the linked Diagram.
In the mean time, run a Jumper Wire from the (-) of the Amp Gauge to the (+) side of the Battery, and see if she cranks over. If she cranks over, then its the fuse or the Amp Gauge.
