Bolens V belt?
Martin
06-15-1999 13:30:56
Hi I'm checking for my Father in Ireland. He bought a second-hand bolens garden tractor/lawn mower model 13006(I think). He is looking for a V Belt part# 1763200 or the belt dimentions. I did a quick search on the internet and this site and troy-bilt keep coming up. Any help or info appreciated. Thanks
Martin
RayP(MI)
03-16-2002 16:26:09
 Re: Electric PTO for JD 317 in reply to Fred, 03-14-2002 06:25:38
Possible short in the wiring harness? Maybe even the coil in the clutch. My coil was potted in epoxy and what looked like sand! Over the years, it disintegrated, allowing the coil to rub on moving parts. New clutch was rather expensive, so I took old one apart, threw out the old aluminum wire, figured out how many turns there were, and rewound a new coil of the same dia. copper electric motor wire. Potted it with two tubes of epoxy from the hardware store. Working fine over four years now!
Frank O. Monroe
02-20-2000 05:55:35
 Re: Bolens V belt? in reply to Martin, 06-15-1999 13:30:56
I have a Bolens 850 lawn and garden tractor. I am looking for a coupling between the drive shaft and the transmission. It is about 3 inches in diameter, has two steel plates with a 3/8 inch rubber disk cememted between the two plates. I also need a belt for the low range.
Hope you can help me.
Frank Monroe e-mail fmonroe@ptd.net
Thank you
george
06-17-1999 18:53:18
Martin,
Troy-Bilt bought out Bolens a few years back. Call the 800 number for Troy-Bilt and ask for a tech rep first. They have all the parts manuals and eng. specs for the Bolens equipment. They can trace it for you or tell you what they need for further information--then refer you to the order department from there--kinda pricey, though.
Martin
06-18-1999 12:24:03
 Re: Re: Bolens V belt? in reply to george, 06-17-1999 18:53:18
My brother was able to get the belt dimentions from Garden Way (troy-bilt). Thanks for the help
Martin
David Castiaux
06-15-1999 19:56:24
Hi Martin, I got out my trusty Gates special applications catalog and I'm sorry to say it didn't show that tractor number or the belt number.If you can come up with anything else I'll give it another shot for you. David in OKC
