Cub Cadet 1872 Super Garden Blades Won't Stay Enga
Al Duresa
08-30-2005 09:03:47
I have a Cub Cadet 1872 Super Garden Tractor. When I turn on the PTO switch, the blades begin to turn, but when I start cutting grass the blades disengage. When moving slow, slow, slow, slow, the blades stay moving, but moving faster, the blades disengage. The disengagement seems to happen as the engine governs itself to keep speed in thicker turf. Its like the RPM's kick up and the blades stop moving. Soemtimes it also happend when going over a large bump or in the process of turning. I figure it the PTO switch is getting old, but was also wondering if its what ever the swicth is turning on. Also, I'm looking for a complete manual with parts list.
Geary Senterfitt
09-19-2005 19:38:30
 Re: Cub Cadet 1872 Super Garden in reply to Al Duresa, 08-30-2005 09:03:47
I have inherited my uncle’s cadet model 1872 garden type tractor that he used to mow the two acres across from his home. I made a call to one place and that called it a super garden tractor for some reason, he knew no other information. I believe it to be a 1989 model because his wife said that is when they purchased it new. I do not have a manual for it. He took fairly good care of it and has not been used or started in at least 6 years since his death. The engine is free but I have not tried to crank it as of yet. The following information was taken from the tag on the side of the housing above the operators left footing and from the mower deck plate.
Model# 149720100
s/n 786919
Date of manufacture C099G
Deck data plate
60” deck 8374190
884091 190 374100
My question is as follows
This small tractor has a 3 point hitch on the rear and hydraulic connections on the front. I can not locate a PTO shaft and that is what I mainly need. I need a small pto to power a small generator that requires at least a 16hp engine that will turn 3600 rpm’s or use a ratio box to provide the required rpm’s.
On the rear of the tractor I see a oblong hole which is located under what looks to be a PTO guard….but where is the PTO shaft or the provision for a shaft????. Is there a pto unit offered for this model 1872 tractor? Was it an option since I have provisions for it? How did it operate off the Kohlor horizontal engine – which has a main drive belt that is at the front of the tractor. If so how hard will it be to locate it? How much can I expect to pay for the complete PTO used unit? How much trouble is it to install???
I have a 1982 John Deere model 314 with a 14hp Kohler engine and the pto option comes off the front of the engine, but seems very similar to the cadet’s belt system.
Any help or information is appreciated.
Geary Senterfitt
gws@gulfwidesafety.com
R Bedell
08-30-2005 09:32:53
 Re: Cub Cadet 1872 Super Garden Blades Won't Stay in reply to Al Duresa, 08-30-2005 09:03:47
Go to this link:
Set the Air Gap to .010 Inches
