12 H.P. B. S. alternator problems
Bolens Boy
08-31-2005 18:29:27
I have a Bolens garden tractor w/ a 12 H.P. Briggs / Stratton engine. For some time I've been dealing w/ the battery going dead. After pokin' around I noticed that a wire coming from under the flywheel was broken. I assumed this was for the alternator / generator, whatever you call it, I tested for voltage and found none. I removed the part, which looks like a ring w/ copper wire wrapped around it and one lead wire which returns back to the ignition switch. I tested this part with a cheap muti-meter and found that it had continuity from the lead wire to the ground of the ring. Should this part have any resistance? If yes, do you happen to know how much. I did replace it w/ a different used one still did not read any voltage. I may have gotten a bad replacement but I prefer not to go with the trial and error process. Any help is greatly appreciated.
Thanx, Speedy
jd4020
08-31-2005 20:13:42
 Re: 12 H.P. B. S. alternator problems in reply to Bolens Boy, 08-31-2005 18:29:27
your going to have to give us more info ,The engine modle #. But most of the chargeing systems are a a/c generator with a diode or two that turn it into d/c. In some case the alternator/ generator will have two wires and one runs a/c lights. Most of the times the diodes break or become disconnected.
Bolens Boy
09-04-2005 10:10:19
 Re: 12 H.P. B. S. alternator problems, Mod. # in reply to jd4020, 08-31-2005 20:13:42
The engine model # is 281707. The type is 0127-01. The code is 88041811.
Thanks
Speedy
