14 hp Briggs floods out
ScottinTN
09-01-2005 10:34:54
I have a MOwer with a 14 HP Briggs engine. After mowing for a while and shhutting the engine off it will not stop the fuel from entering the engine. The fuel shut-off solenoid seems to be working. This happened before so I put a fuel shut-off valve in the line to stop it. Now I used it again and the same thing happened. How can I get this to stop pouring fuel in to my cyl.? Should I replace the fuel solenoid? Run it out of gas after I shut off the fuel with valve? ANy help is appreciated.
Thanks,
Scott
Dannie
09-01-2005 13:55:20
 Re: 14 hp Briggs floods out in reply to ScottinTN, 09-01-2005 10:34:54
Time to clean carburator & check float before you blow engine.
Darren
09-02-2005 21:48:09
 Re: 14 hp Briggs floods out in reply to Dannie, 09-01-2005 13:55:20
I would check the needle and seat because it sounds to me like that it is proably worn and not seating properly and aloowing gas to run by it when the float bowl is full thus runnig in youer clynider and flooding youre engine and fowling spark plugs
