14hp Briggs OHV problem on Simplicity mower
fireboss
09-04-2005 18:52:56
I recently bought a used Simplicity mower powered by a 14hp Briggs & Stratton OHV vertical shaft engine. It would run for awhile then die, and I though I had the problem solved with a replacement fuel pump. It ran fine at idle and while mowing short grass, but when the engine came under heavy load (tall grass), it the engine would "romp" up and down a few times and then die. It would restart, but then soon die again. I fully admit to not being much of a small engine mechanic. Any tips??
Kent of SW MO
09-05-2005 12:43:08
 Re: 14hp Briggs OHV problem on Simplicity mower in reply to fireboss, 09-04-2005 18:52:56
I think you need to replace the coil ( Magnetron).Sounds like it is going bad when it get hot.
Kent
saldana17
10-01-2005 18:48:30
 Re: 14hp Briggs OHV problem on Simplicity mower in reply to Kent of SW MO, 09-05-2005 12:43:08
When my 16 HP vertical did that it was the air cleaner. It may look good but it wasn't I replaced it with new and back to the "REVS" I went. Brad
