12 H.P. B.S.
Bolens Boy
09-06-2005 18:56:44
I have a Bolens garden tractor w/ a 12 H.P. Briggs / Stratton engine. The engine model # is 281707. The type is 0127-01. The code is 88041811.
For some time I've been dealing w/ the battery going dead. After pokin' around I noticed that a wire coming from under the flywheel was broken. I assumed this was for the alternator / generator, whatever you call it, I tested for voltage and found none. I removed the part, which looks like a ring w/ copper wire wrapped around it and one lead wire which returns back to the ignition switch. I tested this part with a cheap muti-meter and found that it had continuity from the lead wire to the ground of the ring. Should this part have any resistance? If yes, do you happen to know how much. I did replace it w/ a different used one still did not read any voltage. I may have gotten a bad replacement but I prefer not to go with the trial and error process. Any help is greatly appreciated.
Thanx, Speedy
shannon from ohio
09-06-2005 23:53:15
 Re: 12 H.P. B.S. in reply to Bolens Boy, 09-06-2005 18:56:44
Yes,it will have some resistance.can't tell you how muck but it won't be that high. When you checked for voltage coming off the wire did you have your multimeter set on ac volts? This is because ac comes out of alternator then gets rectified with a diode which is inline from the lead which changes it to dc to charge the battery..Voltage will vary with engine speed with max voltage at 3600 rpm....
