Kholer 8HP not Charging Battery
2cents
09-18-2005 15:12:50
I`ve got a kohler 8 hp on a B-80 WheelHorse that runs fine as long as I charge the battery, any ideas on how to get it to charge the battery on its own? I dont know to much about the kholer charging system Thanks in advance
deanop
09-20-2005 12:31:41
 Re: Kholer 8HP not Charging Battery in reply to 2cents, 09-18-2005 15:12:50
if your able to download kohlerengine manual, it has a section re; charging section....my guess is the rectifier is bad or connections...its easy to test with multimeter per manual...see if you can look up in the manual..otherwise get back to us and will explain further....deanop
gregg
09-18-2005 19:07:50
Check and clean ALL conections , both ends of battery cables, voltage reg ground and all other wiring. A good service manual can be downloaded @ www.kohlerengines.com
