1320 mower deck belt
SLH IN MO
09-19-2005 17:38:01
I have 1320 cub cadet can anyone tell what the size of the belt is that runs the mower deck comes from the engine to the deck. cub number is 754-3038. I need a lenght and with.Thanks again for the help.
JT
09-20-2005 16:40:46
 Re: 1320 mower deck belt in reply to SLH IN MO, 09-19-2005 17:38:01
Unless cub Cadet has changed, I would not recommend using an aftermarket belt on it. Cub used to use some odd size belts and non OEM belts did not last enought to realize the differance in price. Do not know if that is the saem any more.
R Bedell
09-20-2005 00:01:09
The Part Number is replaced by 954-3038. The Data on that belt is: Sec A x 60.5" (You could use a .50 x 60.5" belt also)
Kent of SW MO
09-20-2005 06:03:57
 Re: 1320 mower deck belt in reply to R Bedell, 09-20-2005 00:01:09
I would like to add that in the belt industry there are two belt standard. One uses letters for belt sections as in A,B,C etc. Then there is the L series as in 3L, 4L, 5L. The length of these belt systems is measured differently. One measure the outside of the belt and the other measures the inside. On a 4L/ A grove belt the differance is two inches. I do not remember which measures which way but it is something to remember when you are looking for a belt.
Kent
R Bedell
09-20-2005 15:07:06
 Re: 1320 mower deck belt in reply to Kent of SW MO, 09-20-2005 06:03:57
Kent:
YOU ARE CORRECT....I forgot about that. Thus using a 4L Belt would be a 4L620 or 4L630. I couldn't find a 62.5" belt in the 4L type.
