troy bilt rototiller
37 chief
09-30-2005 09:05:56
I have a 80 year model troy bilt rototiller. The problem I have is the shaft in the top of the trans. to power the tines has developed an excessive amount of play. looks like the bearing had moved on the shaft?
Leland
10-01-2005 05:06:12
 Re: troy bilt rototiller in reply to 37 chief, 09-30-2005 09:05:56
Send JT an email but I belive you may need to add shims to correct this problem .
37 chief
10-01-2005 08:48:11
 Re: troy bilt rototiller in reply to Leland, 10-01-2005 05:06:12
I added some shims needed about .090 to tighten shaft back up. Looks like the bearing pushed worm gear further down the shaft/ Who is JT where can I find his address? thanks for the reply. Stan
Leland
10-01-2005 20:55:54
 Re: troy bilt rototiller in reply to 37 chief, 10-01-2005 08:48:11
Just look at older posts here in garden tractor page then send him a message he is or was a dealer .
