troy bilt shift pattern
37 chief
10-01-2005 18:56:02
I was given a troy bilt rototiller, I got it running, but can,t find how to put it in reverse. I move the shift lever up, and it goes foreward, and down and it goes foreward Do they have reverse? Any help will be appreciated. Stan
supergrumpy
10-02-2005 16:08:01
 Re: troy bilt shift pattern in reply to 37 chief, 10-01-2005 18:56:02
if you are talking about the "Garden Way" tillers, the pony works different than the horse, which one do you have????
37 chieg
10-02-2005 22:05:49
 Re: troy bilt shift pattern in reply to supergrumpy, 10-02-2005 16:08:01
I figured it out from the other post. I have the Horse model. Thanks Stan
Leland
10-01-2005 20:59:04
They have a fricton disk bolted to the end of crank shaft about 4" around and when you lift up engine the disk hits the drive pully on transmision and tiller should go backwards .
