430 deere lawn garden
Farmall M Pulle
10-03-2005 09:47:22
I have a 430 that my father owned before passing on and I dont have a manuel. I noticed that it has a hi and lo setting on the right side under the steering wheel and I can"t seem to get it to move, is there a trick to it or is it froze up. Also what kind of a bonehead would put a nonrebuildable cylinder on the steering, $214.00 for a new just because of a .98 seal
Kent of SW MO
10-04-2005 06:14:30
 Re: 430 deere lawn garden in reply to Farmall M Puller, 10-03-2005 09:47:22
The non-rebuildable cylinder come from the dealer/engineering mind set that because of the high labor cost of the dealer it is cheaperto install a new cylinder than rebuild the old one. Also there is less chance of the repair coming back because the repair of the cylinder was not done correctly. Remember most equipment today IS NOT designed for the DO-IT yourselfer. The dealer wants all the repair work IMO.
Kent
mo-jd
10-03-2005 23:36:42
If you will pull back a little bit as you switch you will disengage pin that locks selector in place, cannot disagree with you about cylinder. Yet another engineer afraid to leave his house.
Farmall M Puller
10-04-2005 07:18:05
 Re: 430 deere lawn garden in reply to mo-jd, 10-03-2005 23:36:42
Thanks for the info guys. I will try to pull back on the lever to see if it will switch. Does any know if the steering cylinder from a 318 is the same?
JTB
10-05-2005 16:51:57
 Re: 430 deere lawn garden in reply to Farmall M Puller, 10-04-2005 07:18:05
Dont know what the exact difference is at this time,but infact they are different.
richr
10-09-2005 17:30:01
 Re: 430 deere lawn garden in reply to JTB, 10-05-2005 16:51:57
steering cylinder is definately different, you can rebuild it if you put it in a lathe and cut the weld from the back part of cyl, then weld together when done. also that price they gave you is high, should be around 160.00
