Case/Ingersoll tractor weights
Rod Rogers
06-21-1999 20:09:53
I,m looking for rear wheel and front end weights for a Case 448. Thanks Rod R.
allen davis
03-16-2000 18:33:07
 Re: Case/Ingersoll tractor weights in reply to Rod Rogers, 06-21-1999 20:09:53
rod please call me at 1-800-272-3456 I work for taylor foundry co we specialize in tractor wts
Tim
06-22-1999 09:36:36
I found a inexpensive way of getting wheel weights for my 448. I happen to have two 33lb Weider cast iron weights, I then bought two more from Play it Again Sports for $30. For a total of 66lbs per side. All you have to do is drill the four holes in each plate and mount them with 1/2 carrage bolts and locknuts.
