AC 716 hydro wont move
Mike from cny
10-16-2005 20:10:19
I'm working on a 716 Allis, and not sure where to check/add fluid to the tranny. anyone that could answer this would be a big help! thanks
Karl Brandt
10-19-2005 09:35:17
 Re: AC 716 hydro wont move in reply to Mike from cny, 10-16-2005 20:10:19
You add the oil at the back of the tractor,look were you attach the trailer on the tractor there is a piece of pipe.Undo the cap and add oil.On the left rear side of the tractor there is a little breather cap(just above the axle for rear tire)Pull this cap up and add oil.Use Dexron ATF transmission oil.These Sundstrand hydro's can be rebuilt.
I have several of these tractors,Allis Chalmers and Simplicity.
Karl
les_from_syracuse
10-17-2005 07:24:34
You should be able to download a manual from www.simpletractors.com.
Kent of SW MO
10-17-2005 06:16:45
Are you sure you dump valve, which lets you push it easily is not open. I DO NOT KNOW this mower, but if it is one of the later hydro's there IS NOT any place to check the hydo oil. These type of hydro's are throw away units.
Kent
