Troy Bilt motor
37 chief
10-22-2005 21:36:24
My Troy Bilt has a 8 hp briggs CI motor. There is a small plate held on with a couple of small screws, under the oil filler hole. what is under this plate. Thanks Stan
JT
10-24-2005 05:58:34
 Re: Troy Bilt motor in reply to 37 chief, 10-22-2005 21:36:24
Stan,
if it a litle round tin plate, it is hole for a low oil shut down switch, the hole is on all IC engines, the switch is mostly on commercial equipment, but for about $40.00 or so you can put it on your tiller, then if it gets low on oil, the engine dies, then you do not ever have a low oil engine destruction problem.
Jim
teej
10-24-2005 00:56:38
Some models had a low oil shutdown device that would go in that hole, in place of the cover. Those that didn't use it, just had the cover. It was wired to the ignition module to shut the engine down if the oil level got too low.
Usually those are found on generators, but I've seen them on tillers and other equipment too.
bo
10-23-2005 07:39:01
probably the oil breather or an access to the valves. Take it off and see...won't hurt nothing.
37 chief
10-23-2005 08:35:11
 Re: Troy Bilt motor in reply to bo, 10-23-2005 07:39:01
Ihe cover is in the oil resivor. If I take the cover off the oil would run out. I just changed the oil otherwise I would remove it. I was thinking it may be some kind of oil filter? Stan
