Craftsman LawnMower
Jarrod
06-24-1999 21:06:20
I have a Craftsman 36" 4 Speed Lawn Mower and I dont know what year it is or where to get a manual.Can anyone tell me how to identify it?
Model#502.255790
Serial#11950419
Thanx
keith groves
07-13-2006 19:08:36
 Re: Craftsman LawnMower in reply to Jarrod, 06-24-1999 21:06:20
I have a 46"/automatic dlt inteck v-twin and i need to know belt patterns.
terrie
03-03-2006 12:45:34
I HAVE A CRAFTSMAN REEL MOWER - MODEL # 123.8171
I NEED INFORMATION ON THIS, IT NEED A LITTLE REPAIR. OR IS IT WORTH IT TO FIX IT?
I DONT HAVE A SERIAL #
IF YOU COULD HELP, IT WOULD BE GREATLY APPRECIATED.
Mike
04-25-2002 15:25:14
 Re: ATV Finish Mower Quality???? in reply to Josh, 04-25-2002 13:08:50
I have an older Swisher, back when they were a 40" cut, no anti-scalp wheels, no side wheels, and it does a great job. The only thing that it did, and believe they now have fixed that problem, was when the grass was high, it would leave a line of cut grass, sort of like a windrow. I just recut that on the next pass. I set mine on the discharge side of my WH 48" cut deck and either worked from the middle going out on long, straight yards, or "squared" the yard if it was a big square yard. I really like it. It cut my mowing time in half. They are handy if you want to get done quick or have large open areas. The cut quality of my old one is very good.
Mike
Dave
04-10-2002 13:14:59
 Re: Which garden tractor to buy? in reply to Ken, 03-31-2002 15:16:30
I purchased a new MTD 18hp garden tractor w/46" deck in 1996. I also purchased the 2-stage snowblower attachment. I've been mowing our 7 acres (flat ground and woods)and blowing snow with it ever since without a problem. (Unless you want to count replacing the battery last year!)
Signed: A happy MTD owner. :)
gz
02-10-2001 06:10:52
need chute adapter model #521.244701 for sears tractor attachment vacuum, for sears craftsman tractor mower model #917.258863
gz
02-10-2001 06:10:51
Michael Apodadca
03-27-2000 11:16:08
I have a 4 wheel steering craftsman lawn tractor(1994), I'm in need a a copy of the manuel, specifically the parts page, and exploded view illustrations of both the tractor, and the engine.
12.5 hp i/c b&S.
keith
03-22-2000 15:10:00
Dear sir, I have a 38" cut riding lawn mower. The problem is, when I try to engage the blade, the engine dies. I have put wd40 on the pullies and the blades. Please let me know what the problem is if you know. Thanks, Keith
Michael
03-27-2000 11:13:18
 Re: Re: Craftsman LawnMower in reply to keith, 03-22-2000 15:10:00
to keith,
It may be a carborator problem, but a simple fix.
I had the same problem and fixed it by increasing the octane, I switched to unleaded supreme, and also used a carborator cleaner in the gas tank. as well as spraying a carorator cleaner into my carborator, and changing the fuel filter.
good luck
skimel
07-01-1999 12:42:35
this mower is made by murray--
shawnise cregut
04-25-2000 21:36:01
 Re: Re: Craftsman LawnMower in reply to skimel, 07-01-1999 12:42:35
To Whom It May Concern, I am looking to purchase a transmission for a lawnmower that is approximately six years old. The name is 3 in 1 Craftsman Eager one self propelled lawnmower. Model 917374390. How much and how long would it take to obtain this part? Thank You
M. Stambaugh
04-22-2000 15:05:09
I have a Crafsman 15 h.p. riding lawnmower. I can not get it to pull. I think the problem is in the rear-end. Won't go in forward or reverse. It has a pull-pin for hand pushing and you have to push the pin back in to ride it. Can anyone help??
Rick
06-28-1999 05:40:44
You can call Sears @ 800-FONPART (366-7278)and give them your mower model no. They'll look
up the part and you can order it from them.
Be warned - they're not cheap!
Barb
04-02-2000 20:21:24
 Re: Re: Craftsman LawnMower in reply to Rick, 06-28-1999 05:40:44
Need price of craftsman riding lawn mower belt #144200. Thanks
Tiger
04-29-2000 09:31:05
 Re: Re: Re: Craftsman LawnMower in reply to Barb, 04-02-2000 20:21:24
Barb.....
Go to ..."SEARS.COM".....you can get an 800 number and order the belt....but like someone said...''they aren't cheap''
Good luck
jeff
08-15-1999 14:37:39
You can get it at www.searspartsdirect.com
