1250 cub hydro
rick1
11-06-2005 07:45:05
hi all im trying to find where the spring on the brake peddle attaches at on a 1250 cub hydro thanks
R Bedell
11-06-2005 09:25:15
 Re: 1250 cub hydro in reply to rick1, 11-06-2005 07:45:05
There were two different locations of the spring. It will depend on the Age of your Cub. If you supply a Serial Number, I can better assist you.
rick1
11-06-2005 11:35:54
 Re: 1250 cub hydro in reply to R Bedell, 11-06-2005 09:25:15
serial#2050630u632185
R Bedell
11-06-2005 11:49:50
 Re: 1250 cub hydro in reply to rick1, 11-06-2005 11:35:54
third party image
Your Cub was built in Aug 1978. Here is where the brake spring is located
rick1
11-06-2005 16:20:36
 Re: 1250 cub hydro in reply to R Bedell, 11-06-2005 11:49:50
i see where that end connects now about the other end
R Bedell
11-06-2005 17:10:00
 Re: 1250 cub hydro in reply to rick1, 11-06-2005 16:20:36
One end of the spring connects to that bracket. The other end connects to the Brake Rod. There should be a hole in the Brake Rod where you might install a Cotter Pin. Install one end of the spring in that hole.
rick1
11-06-2005 17:24:56
 Re: 1250 cub hydro in reply to R Bedell, 11-06-2005 17:10:00
i thought that was where it went but i wasnt sure thanks now i can move on to the next step of assembly. (that is when work on the asphalt plant will give me some time right now its dark to dark sucks but gotta do what you gotta do)
stronics
11-06-2005 15:38:43
R Bedell,
Wow, now that is service. There are some nice people in this world.
David
R Bedell
11-06-2005 17:10:40
 Re: 1250 cub hydro in reply to stronics, 11-06-2005 15:38:43
THANKS Stronics.....
