old briggs and stratton engine
Adam s12
11-19-2005 18:44:35
I have a briggs and stratton 10 hp that is about 30 years old. I have replaced the points, condensor and coil yet i can't get a spark. I cheaked it with a ohm meter and everything seems to be grounding out somwhere. any help would be nice.
darl
02-08-2006 17:08:57
 Re: old briggs and stratton engine in reply to Adam s12, 11-19-2005 18:44:35
check the kill wire or the wire going from the coil to the points. I have several old brigs parts and repair manuels get me some numbers and I maybe able to dig farther. Good Luck.
darl
02-08-2006 17:08:39
darl
02-08-2006 17:05:48
Big Bill
11-19-2005 19:21:13
Did you try disconnecting the wire that grounds out magneto ? Also, if you didn't do so, you may want to "scuff" points with some sandpaper. It seems the new ones (particularly aftermarket ones) have a film / glaze on them that needs to be removed on installation. Is air gap between mag. & flywheel set right ? About only other thing could be weak magnet on flywheel - rare but it does happen. Could have gotten a bad part (assuming you got new ones or at least used that you knew were good)- again, rare but it happens. Check these things and let us know how you make out.
venda
11-24-2005 08:39:26
 Re: old briggs and stratton engine in reply to Big Bill, 11-19-2005 19:21:13
I had a problem like this once and it turned out to be a bad ground between the points and where they bolt to the block. Remove the points and make sure that area underneath is absolutely clean and free from any oxidation. Because there is such a small amount of current produced by a magneto everything has to be dry and clean.
