Cub Cadet 106
Abram
11-21-2005 16:36:50
My cub 106 will not start unless i squirt starter fluid in the sparkplug hole and then it will sort of chug for a few seconds then die and when its started and running a lot of gas pours out of the carb onto the ground from the air cleaner. and it has to be tuned every time you start it after letting it sit overnight just to keep it running and blowing out black smoke. does the carb just need a rebuild or something more?
oldrustycars
11-23-2005 19:53:10
 Re: Cub Cadet 106 in reply to Abram, 11-21-2005 16:36:50
carp problem, and drain and clean out the fuel tank. probably some dirt in the needle and seat, so that means dirt in the fuel tank. and change the oil too...its diluted by now.
R Bedell
11-21-2005 18:05:39
You have Carb problems. This Carb needs to be cleaned, rebuilt, and put back in order.
