12 volt conversion for 16 hp briggs, single cyl
squirrel
11-28-2005 12:38:03
any one ever convert a 16 hp briggs to 12 volt battery ign?. Larry
Bob
11-28-2005 16:59:10
 Re: 12 volt conversion for 16 hp briggs, single cy in reply to squirrel, 11-28-2005 12:38:03
A Kohler 12-Volt coil works really well, as it is designed for the duty-cycle (dwell) of a single-cylinder engine, rather than a 6 or 8 cylinder automotive engine. Use the Kohler condensor with it.
The correct coil will not run as hot, nor be as tough on the breaker points as will a coil designed for a multi-cylinder car engine
ldj
11-28-2005 16:47:22
No. But I have converted several other makes including some with external magneto. All had points. You wire up just like any other ignition with battery and coil and use the points in the magneto.
