simplicity mower
acd17toy
12-04-2005 16:24:03
my 6010 mower will not turn over with the igtion switch but will start when i jump across the selonid, replaced selonid, did not fix problem. if i jump start it from a running car engine it will start with the key. there are two "relays" under the seat that is tied into the wiring harnes. what do they do? can some one send me scematic, or pictural of the wiring for this machine? also i can not see any type of saftey switches on the tractor. .
jdjoe_97
12-10-2005 18:49:04
 Re: simplicity mower in reply to acd17toy, 12-04-2005 16:24:03
Provide your email address and if you have high speed internet, I can email you the Manual from simplicity. Need ID number. Joe
JT
12-05-2005 09:09:57
If I understand correctly, you are saying if you hook up a jumper cable to battery, it will start with the key? If that is what you are doing, you probably have a bad battery or bad connections.
JoeK
12-04-2005 17:34:28
All tractors/mowers since 70 or so(some earlier) have one or more safety switches,Clutch/brake pedal,transmission neutral,seat switch,PTO.Any one of these could cause the problem your're having if defective,Most likely would be clutch or neutral switch.Try www.simpletractors.com for more info/diagrams.Lots is available for free,but if you have to join to get whats needed,it's well worth the $10yr to most Simp/AC owners.
