exhaust
alliswd
12-07-2005 15:27:05
the exhaust pipe on my 10 hp mower engine is rusted in tight to the engine. i need a new muffler how can i get the old pipe out of the engine. this on a briggs and straton.
Brian G. NY
12-09-2005 07:07:58
 Re: exhaust in reply to alliswd, 12-07-2005 15:27:05
After you get the old pipe out, it's nice to "touch up" the threads. I was lucky enuf to pick up a few pipe taps at a garage sale (up to 1-1/4" size) for 50 cents apiece for this purpose. I like to use a generous amount of "Neversieze" on the threads when I put it back together. Brian G. NY (also a proud Allis WD owner)
Al m
12-08-2005 05:56:16
I agee with Phill,but first I would run the engine to heat the pipe,shut her down and try the pipe wrench.If no success,cut it off flush and follow Phill's advice,heading Wild cat's warning
Good luck
Al
alliswd
12-07-2005 18:25:20
forgot to mention that the pipe is galvinzed steel about 8 inches long. could the pipe be heated with a cutting torch with out hurting the engine block? and then screwed out while it is still red hot?
Joe bloggs
12-07-2005 16:51:37
what style is it.
Phil in MI
12-07-2005 16:49:40
alliswd, it's easy, just make several hacksaw cuts about 1/8" a part 1/4 the way around the inside of the pipe, punch it in and pick it out. That's it, very easy.
Phil
wild cat
12-07-2005 16:10:47
very carfully
