Case mower problems (long)
Bob W [FL]
06-29-1999 18:10:28
I have recently purchased a Case 220 w/ a triple spindle rotary mower. When mowing if I let the hydraulic lift down the grass gets scalped, so I have to mow with it in the raised position and this does not work to good either. I have the mower set at 3 1/2". Looking at the parts list I noticed that there are two different numbers for the gauge wheels. One for the J40 (my model) and another for the J44. What is the diameter of the J40 wheel part #C26736. Also there are different length lift links for different models of tractors. The Case 220 uses the shortest link (part #C18315) , What is the length of this link. I believe that maybe somebody has put the wrong (longer) links on. The illustration shows the link as a flat piece, one of the longer links has a double bend in it (part #C25702), mine has this bend. I know this is long but I need to know what parts I may need to get.
Thanks
Bob W [FL]
R Rogers
07-01-1999 00:42:57
 Re: Case mower problems (long) in reply to Bob W [FL], 06-29-1999 18:10:28
Bob, You might try the ingersoll web site. www.ingersoll-inc.com Their ph.# is 920-582-5000
Good luck, Rod Rogers
