11HP Briggs Carb Problems
Joe A.
12-12-2005 15:59:58
I have two Murray riders with 11Hp Briggs" on them. Both are giving me fits about running rough! I can"t seem to get the mixture anywhere where it will run right, idle or otherwise. I have heard that cleaning out the carb is the first thing to do. After taking the bowl off, then what? Any tips or words of wisdom would be greatly appreciated. Joe Amy
Corydon, IN
stronics
12-13-2005 04:00:43
 Re: 11HP Briggs Carb Problems in reply to Joe A., 12-12-2005 15:59:58
You need to take off the carb and soak it in a cleaner, then blow out all the holes. Make sure the needle and seat are good. Reassemble making sure the float has the correct distance from the carb body.
Then adjust the carb for idle and high speed if it has a adjustment for it.
Clean the tank and flush the lines.
David
