AC 416H Hydro-Lift Problems
Chris/CT
01-03-2006 15:26:15
Have AC 416H with newly added Hydo-Lift. Worked good for 10-12 lifts then quit, I'm trying a new switch, but unsure of type of switch,anyone know which type switch this is? How do I test the lift without switch? 2 wires off lift Yellow and Red can I try 12 volts to one or the other to see if it is working or not?, The switch is only a toggle switch with 1 position up or down, is this single pole or double pole? any help would be appreciated,Thanks, Chris/CT
scott weyand
01-04-2006 14:00:51
 Re: AC 416H Hydro-Lift Problems in reply to Chris/CT, 01-03-2006 15:26:15
chris a 416 is a eletric lift for a 416 a.c. i have one . mabey you should check to see if you have the right lift in there if you need the electrict lift i can get you one at a very good price. scott
