BREAK IN OIL FOR KT 17
jeff walters
01-04-2006 10:26:13
what would be best to use in this kt 17 for break in oil? what weght oil and what kind! i was thinking shell rotella 15w40! thats what i run in all of my engines!
jd b puller
01-05-2006 20:52:39
 Re: BREAK IN OIL FOR KT 17 in reply to jeff walters, 01-04-2006 10:26:13
If you run that heavy oil especially in the cold, your hydraulic lifters won't work. It will rattle like crazy. JD sells stuff called "break in oil". It's technically designed for diesels, but works well in the gas engines as well. Run it hard for 15-20 hours and then change the oil.
AZJackMc
01-04-2006 20:08:29
I think 15-40 is far too heavy for your small engine. 15-40 Rotella is a fine oil but more practical for a deisel engine in fact I think it is too heavy for modern car engines. Jack
Wiliam Pearson
01-04-2006 18:35:08
For the engines I rebuild Castrol HD 30 weight is used. After a rebuild I will run a engine for 10 minutes then change the oil , then run the engine for an hour and change the oil again. This gets all the small metal particles out of the block that might have been missed while cleaning during a rebuild. Oil is cheap compared to metal.
Bill in Richmond , Va.
JT
01-04-2006 14:24:50
There is really no break in oil used in the Kohler engines. Use the oil recommended in the book as was suggested earlier. Change it after 5-10 hours, then put back in the recommended oil. A lot of guys have been using Mobil 1 Synthetic oil with real good luck, but the first 5-10 hours I would use regular oil as per the Kohler book.
David A. Hodson
01-04-2006 14:02:17
I'd wouldn't use anything but CC or IH low ash 30W. David
gregg
01-04-2006 12:44:29
Way too thick! This time of year 10w30 , summer months 30 weight
R Bedell
01-04-2006 11:23:55
I would use the oil Recommended in your Kohler KT Service Manual TC-2107-C as indicated on page 8.
