Cub Cadet Leaks Oil
Tim W
07-03-1999 18:29:26
I have a Cub Cadet 1710 Hydrostatic that was leaking transmission oil thru a hole in the head ofn 1" hex head"bolt on the top of the transmission. I backed it out as far as I could , blew air around it and tightened it but not completely tight, and it quit leaking. the hole seems to be for some kind of pressure escape,but has to be in a certain position to prevent the oil from coming out. How do you know how tight and what position the hex head should be in?
Tim
Frank Mann
07-11-1999 17:46:39
 Re: Cub Cadet Leaks Oil in reply to Tim W, 07-03-1999 18:29:26
Tim, that is a pressure relief valve,and when they start to leak they need to be replaced. My 1650 did the same thing, replaced them both and cured the problem. they are $75.00 each. Frank-Ohio
