4016 Ingersol
Jeff-IL
02-07-2006 05:18:30
I have a 4016 which I have cracked the block twice right above the mounting bolts.This time it can't be welded. Has anyone else had problems with this? It is a Vanguard engine.Really don't want to spend $ on a new block if it will happen again. Thanks
JT
02-07-2006 06:42:44
 Re: 4016 Ingersol in reply to Jeff-IL, 02-07-2006 05:18:30
Jeff,
the only time I ever see a crack in the mounting on a block is if it was taken off, put back on and had something under the block and the bolts tightened or a twisted frame, unlwel mouting surface.. In 30 plus years of doing work on lawn equipment 90% of the time it is not the engine, it is the mounting area that causes the problem you describe. You might contact Ingersol and see if they have had any issues or bulletins such as you descibe, it could be something twisted being you have it happen twice.
Jim
Jeff-IL
02-07-2006 08:04:35
 Re: 4016 Ingersol in reply to JT, 02-07-2006 06:42:44
Thanks Jim. I have tried to contact Ingersol twice. No response.My dealer says that he has never seen it happen before.I have had bought Case/Ingersol for almost 20 years.Thinking it is time to look at other brands.
