Cub 106 wont start
Abe V
02-25-2006 13:09:40
i cannot get my Cub Cadet to start at all. the timing is set the valves work it makes a nice big spark the carb has a new high speed mixture screw the float has been set the screws on the carb have been set gasoline is getting into the cylinder its sucking in air. everything seems to be working but it wont start. i even burned some of the gas to make sure it wasnt bad.
Sparkynuts
02-25-2006 13:53:54
 Re: Cub 106 wont start in reply to Abe V, 02-25-2006 13:09:40
Well now lets start from the begining. Did you have the motor apart? Does it have compression? A 4 cycle motor has 4 parts intake,compression,fire and exhaust.You need to give more details?
R Bedell
02-25-2006 13:19:49
Well, it takes two things to get a motor to run. (A) Fuel, and (B) Spark. This is assuming the motor is mechanically correct. Go to this link for additional suggestions:
Abe V
02-26-2006 14:54:03
 Re: Cub 106 wont start in reply to R Bedell, 02-25-2006 13:19:49
it has compression it has gas and it has a spark. the engine was rebuilt 2 years ago. everything is how it should be.
