BOLENS TRACTOR 10HP
J.WDSN
11-03-1998 18:48:57
i have a bolens tractor model 192-02 serial#35310 with engine model#tra 10d serial#4467217--- engine is apart,complete,less damaged rod and piston--- has no deck,otherwise seems complete---what model is it and what is value?
kevin
10-23-2002 07:01:01
 Re: BOLENS TRACTOR 10HP in reply to J.WDSN, 11-03-1998 18:48:57
: i have a bolens tractor model 192-02 serial#35310 with engine model#tra 10d serial#4467217--- engine is apart,complete,less damaged rod and piston--- has no deck,otherwise seems complete---what model is it and what is value?
Jacques Lacasse
11-20-1998 18:48:46
_____ _____ _
Your Bolens is effectively a 1050 and the engine a Wisconsin. In good shape, with the engine repaired and a deck it would worth about $1000. It's a robust and well built garden tractor.
Jacques
J
11-03-1998 19:56:41
Its worth $50 if you can find someone who will give you that much
Good luck
Steve Johnson
11-03-1998 21:28:24
 Re: Re: BOLENS TRACTOR 10HP in reply to J, 11-03-1998 19:56:41
Your Bolens is a 1050 and is a 1967,68, or69
: : : i have a bolens tractor model 192-02 serial#35310 with engine model#tra 10d serial#4467217--- engine is apart,complete,less damaged rod and piston--- has no deck,otherwise seems complete---what model is it and what is value?
: Its worth $50 if you can find someone who will give you that much
: Good luck
