1650 cub brake spring
bo
03-11-2006 13:47:20
Have a Cub Cadet, 1650, hydrostatic,the brake return spring rusted out and broke, got a new one and I have no clue what it hooked to. This spring is 6"long with hook on each side, one hook longer that the other. All it does is hold the brake pedal up. If anyone with a 1650 or similar, could look at theirs and tell me where the hooks hook to I'd appreciate it. If you sit on the seat and look down with the cover off the driveshaft area, you should be able to see it. I think it goes on the left side. A digital picture would be fantastic.
I check every manual I had to see a picture by chance and nothing. Thanks.
R Bedell
03-11-2006 16:51:15
 Re: 1650 cub brake spring in reply to bo, 03-11-2006 13:47:20
If you supply an Email Address, I will send you two Pictures.
bo
03-11-2006 17:25:44
 Re: 1650 cub brake spring in reply to R Bedell, 03-11-2006 16:51:15
abpikas@att.net..... .excellent, outstanding...yes, internal brakes. Thank you.
R Bedell
03-12-2006 01:43:07
 Re: 1650 cub brake spring in reply to bo, 03-11-2006 17:25:44
You should have mail..... ..
bo
03-12-2006 05:41:52
 Re: 1650 cub brake spring in reply to R Bedell, 03-12-2006 01:43:07
Yes...got it...super appreciate it. One picture and it does more than any verbal explanation. You're rebuilding that tractor? There's no other explanation why it so immaculate. Thank you.
R Bedell
03-11-2006 16:42:57
Would I be correct in assuming, that your 1650 has Internal Brakes...???
