12 HP techumseh
vjd
03-12-2006 18:28:25
when I run the starter it will fire and kick the engin backwards but once it is running it runs good, there is no points on it the mag is .015 air gap the carb has been all redone, why dose it kick backwards and about tare the starter out of it?
VJD
03-12-2006 20:08:19
 Re: 12 HP techumseh in reply to vjd, 03-12-2006 18:28:25
I checked the fly wheel key an it is ok
Bob
03-12-2006 20:53:31
 Re: 12 HP techumseh in reply to VJD , 03-12-2006 20:08:19
How about the valve settings... not sure about this engine, but on some small engines, valves gapped too wide will affect compression release for starting, and engine will "kick".
If you don't get any better help here, you might try the Tech Forum at www.perr.com. There are Tecumseh GURUS over there.
Bob
03-12-2006 19:50:38
Have you checked the flywheel key?
