Crank shaft Prep?
Dean Minn
03-15-2006 16:13:03
I have a 8hp kohler the connecting rod broke.What is the best way to clean the aluminum off of the rod journal?I heard to use some kind of acid?I need to mic the crank to see what kind of a mess it is.Thanks for all the advice. Dean
Ken Combs
03-16-2006 15:46:18
 lye in reply to Dean Minn, 03-15-2006 16:13:03
Acids will attack the crank. Lye will disolve aluminum but will not hurt the crank.
JT
03-17-2006 05:27:36
 Re: lye in reply to Ken Combs, 03-16-2006 15:46:18
Ken, I have been using muratic acid for years and it has never "attacked" a crank. The only thing muratic acid will do is remove all the oils off the steel, so it will flash rust real quick.
It will dissolve aluminum though and does a great job, it is slow, but it cleans it up.
Jim
Ken Combs
03-17-2006 12:35:40
 Acid in reply to JT, 03-17-2006 05:27:36
All I can say is that I use it to remove rust from parts and if left in the tank for too long, steel parts are pitted. The longer they are left, the worse it gets.
Kent Redd
03-16-2006 05:57:59
 Re: Crank shaft Prep? in reply to Dean Minn, 03-15-2006 16:13:03
If you have aluminum built up on the rod throw, you may need to have the crank turned .010 undersized. I would take it to an automotive machine shop to have it checked out. I have a crank from a K-301 in the shop now. It would not clean at 10 under. They are welding the throw up and will grind it back to standard.
Kent
JT in Illinois
03-15-2006 16:40:26
Dean,
If you go to a local radiator shop, see if they will sell/give you a little bit of muratic acid 6-7 oz is more than enough. Muratic acid will remove aluminum slowly, but it will not hurt the steel. It will super clean it, all oil off of it, so you do not want to remove the aluminum and then walk away, ti will flash rust immeidatly. It takes a lot of time to do it this way, so ne patient and use in a well ventilated area, it stinks to high heaven.
Jim
