2 wheel walk behind plow
J Parker
07-13-1999 18:16:19
I have an old Bolens 2 wheel walk behind plow that has a five horse motor with vee belt going into a vee belt pulley on a shaft. The pulley is vee belt on the left side and sprocket for chain drive on the right. It has a # 990583A stamped on the side. I need this part. The walk behind has type # 12BB04, and serial # A27642 stamped on the ID plate. I only have half of the pulley. If anyone knows where I can find this part please reply to this message. I would really appreciate it, Thanx.
Rob Haw
12-21-1999 17:16:56
 Re: 2 wheel walk behind plow in reply to J Parker, 07-13-1999 18:16:19
I have two late 40's early 50's bolen two wheel tractors and have also been looking for parts, the wheel hubs are the major items I need. Both are 4hp with the green hoods with yellow strips and oil bath air cleaners. I have broken two of the hubs and have been looking for replacements. Please email roberthaw@home.com with any info.
Thanks.
Noel Cervino
07-14-1999 12:17:59
I also have an old Bolens 2 wheel walk behind - I know where an old basket case is that may have your part, but I'm not clear on which part you need from your description. I'll look at mine later this evening and try to sort out which pulley you need. My email address is: nacervino@home.com
Do you have any idea where I can get any manuals or other sources of info on these units?
Graydon Wayman
12-13-1999 14:51:34
 Re: Re: 2 wheel walk behind plow in reply to Noel Cervino, 07-14-1999 12:17:59
I have a 1934 bolens plow tractor in good shape,it is a ez-22,has old bridges engine which siphons the gas up to the cylinder,runs good but could use a ring on the piston.Has 22" tires that are new,Have used it a lot but not in the past few years,may be for sale, If interested contact me @ the above address ,I live in N.E.Pa.
