Tecumseh engin fireing to soon
vjd
04-10-2006 19:38:24
tecumseh 12 HP engin fires to soon and kicks the starter back, has new spark plug in it, I watch it turn and it will fire about 3 inches on the fly wheel to soon ( top dead center) i know it should fire a few degrees befor top dead center could there be a gear tooth broken in it. need all the help I can get now. If you like you can send it to vmdonelan@msn.com Thanks Vince
JT
04-13-2006 06:16:15
 Re: Tecumseh engin fireing to soon in reply to vjd, 04-10-2006 19:38:24
A vey common problem on Tecumseh engines are the valve gap is too wide, it needs to be set at .004 on the OHV engines. If the valve clearance is not set at .004, the compression release will not work, and then it will kick back agaisnt the starter like you are descibing.
Bernie@LMC
04-12-2006 21:57:57
i was reading in another forum about the valve clearence being to tight and the intake opening sooner than it should thus causing the engine to "kick" stop over at www.lawnmowercentral.net one of the guy's there may have answers as well.
vjd
04-12-2006 16:41:25
 Re: NEED MORE INPUT ON THIS ENGIN in reply to vjd, 04-10-2006 19:38:24
I need more input. got a new spark plug the fly wheel key is good all the timming on the inside of the moterline up ( moter is split now so I can see the inside of the engin )Have not checked the rod but I am sure it is ok it comes to the very top at dead center. Can Any one think of any thing else?
Kent of SW MO
04-11-2006 06:10:04
Is the flywheel key sheared?
Kent
Kelvin
04-10-2006 19:42:32
What is the model number?
vjd
04-10-2006 19:49:53
 Re: Tecumseh engin fireing to soon in reply to Kelvin, 04-10-2006 19:42:32
Kelvin I will have to get back to you tomorrow dont have the engin here
vjd
04-10-2006 20:03:33
 Re: Kelvin got noumbers in reply to vjd, 04-10-2006 19:49:53
Ser 3119D mod OHB12-202714A Exter life Tec 12 OHB Over head velve
vjd
04-11-2006 18:50:22
  no it not in reply to vjd, 04-10-2006 20:03:33
the fly key is not bent, I now have the engin opened up cant see any thing wrong in side
rustyj14
04-12-2006 17:50:28
 Re: no it not in reply to vjd , 04-11-2006 18:50:22
Flywheel key does not bend--it shears off. Caused by a backfire, loose flywheel nut, sudden stop of engine rotation due to broken connecting rod! On a rotary lawn mower, hitting the water or gas curb box, or a pipe hidden by weeds or long grass, which stops the engine quickly, will definitely shear the flywheel key! Note: when you put the engine back together again, pay strict attention to the timing marks on cam and crankshaft gears, and also to getting the governor in correctly! Its a bit tricky getting it all back in where its supposed to go!
