BELT REPLACEMENT
JACK LANG
04-11-2006 09:48:33
I HAVE A SEARS CRAFTSMAN 11 RIDE AND MULCH TRACTOR. I NEED TO REPLACE DRIVE BELT. DO IHAVE TO REMOVE SHAFT TO GET NEW BELT ON TRACTOR?
Rustyj14
04-11-2006 17:47:06
 Re: BELT REPLACEMENT in reply to JACK LANG, 04-11-2006 09:48:33
Are you asking about the mower deck drive belt, or the main drive belt to the transmission? Please advise! Rustyj
JACK LANG
04-12-2006 05:07:08
 Re: BELT REPLACEMENT in reply to Rustyj14, 04-11-2006 17:47:06
I AM TALKING ABOUT THE MAIN BELT DRIVE.
rustyj14
04-12-2006 17:37:08
 Re: BELT REPLACEMENT in reply to JACK LANG, 04-12-2006 05:07:08
I've found, if you don't have the schematic or the book, and the old belt is still on the machine, it is best to jack it up, set it on something steady, remove the deck, then lay down with a paper pad and pencil, and sketch out how the old belt is routed! Believe me, when it comes time to install the new one, you can end up with too much belt! (Theoretically) And, as you lay there cussing yerself for not making the sketch, you'll try all combinations of routing of the belt, until after many tries, you'll finally get it right! don't ask me how i know!! I am assuming you know to write down all numbers on the machine, when you go to buy the belt! These numbers are usually on a paper sticker under the seat, or someplace nearby, or even under the hood! Well, good luck. hope it doesn't turn into a fiasco. Most belts are fairly easy once you lay down and look at them. You may have to remove a rod, lever, or something in the way! the designers don't make things easy! Lastly, buy the belt at the dealer's store, or a lawn mower parts place, don't just go down to wally world and buy some cheapy belt--you'll regret it, as you lay under the machine, replacing the cheapy belt sooner than later! Rustyj
JACK LANG
04-13-2006 06:20:25
 Re: BELT REPLACEMENT in reply to rustyj14, 04-12-2006 17:37:08
RUSTY
THANKS FOR THE INFO, BUT THE BELT WAS ALREADY BROKE AND APART. I WAS LOOKING UNDER THE TRACTOR BUT I COULD NOT SEE HOW TO ROUTE BELT WITHOUT PULLING THE BELT PULLEY OFF TO GET BELT AROUND PULLEY. AND OF COURSE STUFF IN THE WAY. I DON"T THINK I HAVE ANY OTHER OPINIONS??
THANKS AND IF ANY MORE IDEAS LET ME KNOW. JACK
rustyj14
04-14-2006 15:48:27
 Re: BELT REPLACEMENT in reply to JACK LANG, 04-13-2006 06:20:25
Jack: Try: www3.sears.com
