BS Intech Twin 22 hp
tommyjoe58
04-14-2006 11:39:43
I went to start my TB garden tractor w/ the above engine. It would not fire. I sprayed some carb cleaner in and it fired two times only did not start all the way both times. Now it will not fire at all. It had bad gas in it. I drained gas tank and lines, checked spark, checked for sticky valves, and seems to have good compression (no comp. gage but blows good with plugs out and turns hard with plugs in - normal). I have not checked the float bowl solenoid but the engine still will not even fire when I prime through the carb.
I’m at a loss. What am I overlooking?
JT
04-14-2006 12:53:55
 Re: BS Intech Twin 22 hp in reply to tommyjoe58, 04-14-2006 11:39:43
If you have water in the gas along with bad gas, it will not fire no matter what you do. You also have to drain carb, clean high speed jets, drain tank,new fuel filter, new plugs, then you should be good to go.
Jim
