15.5 Briggs
RedJD
04-14-2006 21:43:26
I bought a mower a couple years ago with a 15.5 B&S single cylinder overhead valve engine.At the end of the summer last year I started having trouble with the starter.I bought a new starter and battery but after only a short time the new starter started going bad. Someone told me Briggs had trouble with this engine,that the compression realease didn't work properly.It does act like it has too much compression for the starter.Anyone out there had this problem?
RedJD
04-15-2006 07:41:33
 Re: 15.5 Briggs in reply to RedJD, 04-14-2006 21:43:26
Thanks guys for the help.
Ichabod
04-15-2006 03:36:41
Kent is right. Find your specs below.
Ichabod
Kent of SW MO
04-15-2006 02:52:18
Check valve clearance. If the exhaust valve clearance is to wide the decompression release wil not work. I do not have the clearances at hand to post them.
Kent
