BS 14HPRuns only with choke closed
Les Ball
04-28-2006 18:16:22
Cub Cadet 1440 w/ B&S twin cyl will only run when the choke is closed. I have repl fuel filter, plugs, have taken breather off and looked into carb, nothing visible, does anyone think that the fuel pump could be bad ?
Bret4207
04-30-2006 05:18:28
 Re: BS 14HPRuns only with choke closed in reply to Les Ball, 04-28-2006 18:16:22
I"ve had good luck using Berrymans B-12 (I think) Chemtool carb cleaner. Add about 1/2 can to the tank and run it for a while.
lucasss
04-28-2006 19:09:19
dirty carb..... .. go figure...
Les Ball
04-28-2006 19:22:51
 Re: BS 14HPRuns only with choke closed in reply to lucasss, 04-28-2006 19:09:19
so, clean the carb by taking it off, or rebuild ?
