Allis B110 mower deck
Rusty82
05-03-2006 17:39:46
I have a B110 I finally got running, this may sound stupid, but, which direction are the blades supposed to turn, clockwise or counter-clockwise? The blades that came with either weren't the right ones or my deck is spinning backwards. I have gone over the manual countless times to make sure everything is in the right place. Any help would be Greatfully appreciated. I want to get off the Craftsmen mower. Rusty
alm
05-04-2006 10:52:33
 Re: Allis B110 mower deck in reply to Rusty82, 05-03-2006 17:39:46
I have a symplicity landlord,same thing.You just need to put a half twist in the belt to get her spinning the opposite way
good luck
Al
Rusty82
05-04-2006 18:20:21
 Re: Allis B110 mower deck in reply to alm, 05-04-2006 10:52:33
The twist did the trick, I had it twisted but the wrong way. What a relief, the thing mows great!
Thank you guys for all your help. Rusty
Sgt. Rock
05-03-2006 18:11:42
I have a Allis-Charmers B110 and the blades go counter clock wise and is a left hand discharge. Hopes it helps.
Bob
05-03-2006 18:08:47
The discharge is at your LEFT, isn't it? That is the opposite of most, and the blades also turn opposite of most common units. Looking at them from the bottom up, they turn CW, right?
Are the blades held on with 2 bolts? If they were held on with a single RH thread bolt, it would unscrew under load, and the blade would fly off!
Most, more common mowers discharge towards the operator's RIGHT, and the blades turn CCW, as viewed from below the deck.
Rusty82
05-03-2006 19:03:46
 Re: Allis B110 mower deck in reply to Bob, 05-03-2006 18:08:47
Thanks for the help, at least I know I was thinking right, it is backwards. Going the same way as the ole craftsman. Now, WHY? The belts will only wrap around the pulleys 1 way.
Bob
05-03-2006 19:46:56
 Re: Allis B110 mower deck in reply to Rusty82, 05-03-2006 19:03:46
I wish I could help you. I had one YEARS ago, and can't remember how the belt was threaded.
Have you been to:
Link
Someone there will be able to help you!
