1641 sputter
Dave Richards
05-11-2006 13:39:27
two things and dont know if they are related. I`ve noticed once in a while that my alt.light comes on after I start the tractor. Kinda dim and not for very long. Yesterday I noticed it on and the motor spit and sputered untill I shut the pto off. The tractor seems to sputter when under load. If I hit taller grass or even just turning the deck on. If I stop and either shut the deck off or just sit and let the tractor catch its breath it smooths out. Any suggestions? Thanks in advance, Dave
Darryl_MO
05-11-2006 22:34:08
 Re: 1641 sputter in reply to Dave Richards, 05-11-2006 13:39:27
The alt. light on my 1641 began to light up as you describe and eventually got brighter and stayed on. Advise from this forum lead me to replace the voltage regulator and that solved the problem. About the sputtering, perhaps if a bad regulator resulted in a weak spark situation it could cause your problem. Or carb? Or governor?
