JD 265
ACSam
05-15-2006 16:36:49
I just purchased a 265. I have some hills to mow and usually have to add weights to be able to do this. My old 210 has a cast iron rear end and handled extra weights with ease. Will the 265 with aluminum rear end handle the exra weight without problems. I"m swithching rear tires with weights on them(fluid in tires and wheel weights). They weight 125lb each. I"m concerned about the aluminum housing. Will it work with reasonable care? Thanks.
