Brakes don't work on Murry 11
(None)
05-20-2006 15:02:18
As the name applies I have a Murry 11 that the brakes do not work on. You can put the park brake on and still go with out feeling a thing! How do I go around fixing this? It has what looks like one rotor to hold the tractor back!...On a side note I notice that the left side of the rear axil is not attached to anything. Is this normal because I can see no damage but if so this is a wierd feature.
Dannie
05-21-2006 03:15:57
 Re: Brakes don't work on Murry 11 in reply to (None), 05-20-2006 15:02:18
Most murrary brakes work with 2 disks that close on a rotor when the pedal is pushed.2 bolts hold brake housing to transmission.If brake rod moves 2 pins push outside disk against rotor.To repair check brake rod is it working,is it hooked up,next spray brake free or WD40 on the 2 bolts where they go into transmission and be very careful and not brake them off as you try and remove them.If disk are bad replace,if disk are good clean pins and replace.Good Luck.
