7/8 dia crank 3-5/32 long vertical 10HP engine = h
buickanddeere
05-25-2006 10:58:47
Anybody had any luck turning down the ordinary 1" dia Tecumseh TVM220 crank to 7/8"dia so it will bolt to the JD pulley set? I did see refernce to a crank #37660 which is supposed to be 7/8"dia & 3-5/32 long, hen's teeth there too. I want to set the origional 7HP aluminum block engine aside a acollector's piece before it pitches a rod through the block. It's pretty gutless too on the old model 68 JD mower. A 10HP TVM220 with electric start would reduce the complaints from the women folk around here. Less stalling and easier starting.
Kent of SW MO
05-26-2006 06:19:04
 Re: 7/8 dia crank 3-5/32 long vertical 10HP engine in reply to buickanddeere, 05-25-2006 10:58:47
If you could come up with another pully set it might be easier to bore ou the pulley to 1 inch unless the pulley is one of the "tin type" where there is not room to bore the hub.
Kent
buickanddeere
05-27-2006 17:43:38
 Re: 7/8 dia crank 3-5/32 long vertical 10HP engine in reply to Kent of SW MO, 05-26-2006 06:19:04
The mower drive pulley is on a kind of extention bolted to the end of the crank. If the pulleys were both directly mounted on the crank then a 1" shaft would be no problem. I'll have to keep looking for a 37660 crank. Or put another little under powered engine on there.
