1655/1650 massey/snapper
Ohio Case
05-30-2006 14:24:38
What is the difference between these two? Will the rearend assembly and driveshaft from the 1655 fit into a 1650?? Thanks in advance
mn.Chuck
05-30-2006 15:31:52
 Re: 1655/1650 massey/snapper in reply to Ohio Case, 05-30-2006 14:24:38
The rear axle assembly is a different p/n mostly
because of the axles and axle housings. I can't
imagine that the complete assemblies couldn't be
switched. The driveshafts are compl.different but
looks as if the l655 has a universal vs.the 1650
with a splined coupler. Poss. it would hook up.
The 1650 powered by 16hp Kohler(wt.1040 lbs).The
1655 has 16hp Onan(wt.1120lbs).Built '77 and '78
Then Snapper bought out and there first ones were
the same-saw a new Snapper at the fair and still
had MF s/n plate. Chuck
